BoroBoroS13 »
https://forums.nicoclub.com/boroboros13-u12213.html
Fri Sep 17, 2004 9:01 am
I replaced the Water Pump, Spark Plugs, Timing Belt, Thermostat, PCV Valve, ALT Belt and Rear Main Seal before I put my motor in.
But now the seals on my turbo are going bad and there is some shaft play.
I plan to pull the motor out very soon and rebuild it from the ground up. I am going to replace the piston rings, oil pump, have the head rebuilt, and a whole lot of other bs. The only thing that sux is I plan on doing this over a very long period of time and wont have my CA18 back in till next year. Oh well, better to do it right the first time and not cut any corners anyways.
