Q-less »
https://forums.nicoclub.com/q-less-u12928.html
Sat Dec 25, 2004 1:43 pm
I thought I would check the MAF sensor and I removed the white clip, saw no corrosion. I figured I would remove the male black connector that sticks out of the MAF, BIG MISTAKE, I didn't know it shouldn't have come off...Doh!! So, I go to the neighbors to borrow a soldering iron and before I leave he has an idea to solder three lead wires to both ends and then stuff it back together. I saw no way of soldering it like it was so I thought I would save myself some time and do what he recommended. It worked, took about 30 minutes of detailed soldering, but it worked. I had to bend the leads, ever so carefully, to a straight position.
So, why the 4 little screws if you shouldn't take it off.
I took the car out for drive and no stalling and the temp gauge went to normal again, but it seems to decrease whenever I really stomp on the gas. But still no stalling. I guess the intermittent stalling is the alternator failing, hence the 'low charge warning.' I've had alternators act funny like that in the past. Can you do the old alternator test on the Q, remove the battery cables and if the car dies, your alternator is bad? Anyhow, I've got an alternator coming and will have it in case the intermittent becomes terminal.
Modified by CherryPoppinQ45 at 6:49 PM 8/21/2005
Modified by CherryPoppinQ45 at 10:01 AM 8/22/2005
