RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Thu Mar 15, 2007 10:41 am
I will have to rebutle that altered atmosphere's angled plenum 5/16 spacer added 13whp to a z they dyno tested bone stock before the mod and immediately after installing it. STock was around 220whp and with the spacer it was 233whp. Then they had A.A. reflash the ECU and gained another 13wph. The ECU flash was more than the spacer with same gains. The gains are probably less on an automatic than a manual, which is why the results you state are only 7hp. Still the best bang for you buck mod, period. The 5/16 spacer is only 240 bones. What else are you going to buy for a NA car and net anything over 7hp up to 13? You spend 1k on an exhaust sytem and still wouldn't get those gains.
