How many gallons to pump in Gas Tank?
SHIFT_CR
Car: 08' Altima Coupe 2.5s
Ok, I was wondering how much do yall pump when you are about to be on empty? When I fill up to a full tank, my car feels really sluggish. And dont you get better miles when your car is holding less weight?
MagicM
Car: 2007 Black/alu trim /black interior M35x 2005 Range Rover HSE 2000 Range Rover p38 4.0SE
yes you get better gas milage when you weigh less, but why would you go to the gas station and fill in 1/4 or even 1/2 when prices keep changing everyday, and the mpg is probably offset by you having to go to the gas station more than you need to.
johnny_d
Car: 2008 Altima Coupe V6 SE w/ CVT
a gallon of gas weighs about 6.15 lbs, a full tank of gas is 20 gallons ~ 120lbs. Wow, i didn't know gas weighs that much But hey, I have a 3.5 so it's hardly noticible. Always fill up, save trips to the gas stations ... well, i have to go once a week already
jdshift
Car: 2019 Nissan Altima
2015 Nissan Altima 3.5
2014 Infiniti QX70 S 5.0
Not sure if there is truth to this or not............I was told if you fill up half tank all the time, it's no good and I cannot remember the reason for it. I always fill up, car does not feel sluggish at all.............maybe it's the gas you are getting from the gas station?
SHIFT_2.5S
Car: 2008 Nissan Altima Coupe S 2.5
I think the consensus is evident here. MagicM has solid reasoning, by filling up a full tank, you are saving unnecessary trips. However, if you are going to the track for a 1/4 mile, it's probably best to have about 1/2 tank full.
MagicM
The reason why they tell you not to fill up half way, is mostly for cold weather reasons. It leaves more air in the tank which might freeze your gas. Also People should fill up to full incase of emergency if you ever get stuck in traffic or any other unforseen incident.
jdshift
^ Thanks for that info!!
chow
Car: Altima coupe 3.5SE
Octane has a super low freezing point and i doubt you live in a place that hits - 40+?
From what i've heard is that when you add small amounts of gas to your tank from different manufacturers, you get different types of sediment that set into your gas tank. And i guess different fuels (If not purchased from the same place) contain different contaminents. Also, mixing gas is bad.. I guess cuz pump gas has 100000 chemicals ( like cigarettes) and each manufacture is different.
MadBlackCoupe
Car: 2008 2.5 Nissan Altima Black Coupe
I read somewhere cars get better fuel mileage when their tanks are full, so you should not go under 1/2 tank at anytime to get the best mileage.
Gas Saving Tipshttp://www.fuelmeup.com/tips.php
Holla
MadBC
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Yeah i thought on a full tank you get more mileage bc of fuel pump... idk anything though..
LinkNuc
Car: 2008 Altima Coupe 3.5 SE Super Black 6MT, Loaded minus Moon Roof Deflector
Gasoline's freezing temp (when it starts to freeze) is roughly -97 deg F. But since it is made up of many different hydrocarbons and water content, it has a large range for an actual freezing point...so basically water is bad for that, but all in all gas shouldn't ever truely freeze.
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
LinkNuc wrote:Gasoline's freezing temp (when it starts to freeze) is roughly -97 deg F. But since it is made up of many different hydrocarbons and water content, it has a large range for an actual freezing point...so basically water is bad for that, but all in all gas shouldn't ever truely freeze.
haha, looks like someone took good notes in general chemistry...remember a little something called "freezing point depression" and "metling point elevation"
LongBeachCoupe
2005 Lexus RX
Ethanol?You guys know about gas evaporation at the pump in Cali right?
notaverage
Car: Altima Coupe 3.5 SE w/ tech pkg and VDC. Precision Grey
yes, i do
LinkNuc
Notes in general Chemistry, lol. Try more like copy and paste, lol. Don;t give me that much credit.
