How many electric fans???
DawgMode
Car: 180sx
okay i soon going to get an electric fan setup for my radiator.Which setup should i go with.
1 12" fan
2 12" fans
1 15" fan
or what would you recommend
rudee023
Car: '03 Infiniti Q45
If on a budget, go with some stock electric fans froma FWD Nissan. If money is no object, go with the flex a lite duals.
slow s13
Car: cars, photo, music
40 bucks got me 2 sentra fans from the junk yard
tubakins
Car: 89 240sx fastback
#1-flex-a-lite dual 12"#2- Perma-cool single 14"these are sum of the better of fans dont forget thermostat relay switch
SR20DETPoweredS14
Car: 1999.5 Audi A4 1.8T
I went with a Flex A Lite dual 12" fan setup with a HKS Fan Speed Controller
DawgMode
Car: 180sx
im going to get the el cheapo fans they have on ebay....and to hook em up, im just ganna hook them straight to the ignition so they turn on when i turn the key......
RMiller
Car: BBQing
DawgMode wrote:im going to get the el cheapo fans they have on ebay....and to hook em up, im just ganna hook them straight to the ignition so they turn on when i turn the key......
On ebay the company that sells the reasonably priced fans sells a thermostat with a given temp range. This is a better way to go because it will save you power when the fans aren't on, and it'll keep temps in a favorable range.
Nismo_Freak
Car: 89 Nissan 240SX
15" Single > *
DawgMode
Car: 180sx
Down here in the Bahamas it really doesnt get any lower than 80 degress so i think they will be on all the time anyway even if i got a thermostat
cheez80
Car: percussion =D
please, sir, try to run a shroud. the f-a-l duals are shrouded. (rudee has em)
a shroud will increase effectiveness of your fans by a lot =P
DawgMode
Car: 180sx
i absolutly refuse to spend that kinda money that fal and flex-a-lite want for there setups....ill be fine with the ones on ebay....plus i need the extra space without the shroud
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
yeah i want to make a carbonfiber shroud for my 14" permacool.
Luke
14" permacool gets the job done for me, shroudless.
