rbsileighty »
https://forums.nicoclub.com/rbsileighty-u4927.html
Fri Feb 28, 2003 5:52 am
Here is what MKIV.com says about the fuel injectors on the Supra... I know the 2JZ is not a RB, but it gives you an idea about what those injectors can do power wise on a six (bigger six... but still a six). It kind of gives a good ref point.
fuel rail and injectors: the stock fuel rail and injectors are quality units, capable of supporting the same HP as the stock fuel pump. the injectors are rated at 540 cc/min at 41.2 psi of fuel pressure (~550 cc/min at 43.5 psi), and are a two-hole, side-feed, low resistance design. these injectors enable the hot injector to be cooled by its fuel supply, increasing both hot starting and drivability. push your power past 475 rwhp, however, and your exhaust gas temperatures (egts) may climb due to a leaning-out condition. those pushing the limits of the stock system will need to keep a close eye on this. it would be a good idea to have your injector cleaned and balanced if you plan on pushing 500 rwhp on the stock system.
