sil80drifter »
https://forums.nicoclub.com/sil80drifter-u622.html
Mon Dec 13, 2004 4:58 pm
Before I turboed my 140k SOHC, I've been beating on it really, really hard for about 40k miles, ever since I've bought it with 104k. Two weeks before I turboed the car, I swapped out the injectors (already had the SAFC II in, but didn't tune much, more for getting used to it) and put in some 460cc injectors. Apparently I overestimated how much I needed to tune them down for stock N/A driving on the low end (before 3200rpm) at high loads and low throttle (basically tuned the Low throttle map on the SAFC way too low). The car pinged/rattled hard, but since I didn't expect that to be a fuel problem, I thought it was a timing chain problem, especially since I was worried about the timing chain plastic guide crap in my oil pan (never flushed it after last TC job) to have been clogging my oil ways.
Did the TC job again, swapped oil pans, made sure everythign was clean. Pinging/rattling still present. For a week I pinged on it before I decided to try turning the fuel up (yes, some of us are slow or stubborn). That fixed it. But now when I went to actually turbo the car, it was a KA that has seen 40k miles of abuse and a WEEK of pinging. AND overheating (my thermostat started giving out that same week it started pinging, temps went to 250 a few times). I turboed it anyway. Before the car started pinging, my compression was 150/180/180/150. Two weeks after having turboed it, it started making lots of oil smoke (and not just from the old turbo), and I checked compression again. 105/150/150/95.I assume my rings/ring lands are shot. This was barely tuned motor, and I've done up to 10psi on it at times, and although it was always very rich when boosting, I guess the poor rings couldn't take much more abuse and added pressure.Not the best example, but pretty realistic as far as KA-Ts go.
I'll be rebuilding it this winter, taking a 70k block/rods/pistons, polishing/retapping the crank, new bearings, new rings, new stock headgasket, stock everything else. I want to run 250whp at most, and see how long a stocker in good condition, and well tuned, will last. Hopefully it'll outlive this rusty shell, and I'll be swapping it into a better hatch some time in the future.
I think it would be a good example because few of us turbo stock KAs that are new AND stock, like they came from the factory.
sil80
Modified by sil80drifter at 10:25 PM 12/13/2004
Modified by sil80drifter at 1:01 AM 12/14/2004
