how low would compression be? kae with kade pistons
fo0manchu
was just curious to how low the actually compression would be if you were to put de pistons in a e block?
im replacing a bent rod in my kae block and got 4 stock rods with pistons from a altima ka24de.
Im planning to put this into my datsun 510 and running boost as well. My only problem with a ka motor will be its high torque. I wouldn't be able to hook up, especially if im running a 4.11 rear end and my car only ways about 2000lbs. So I was just thinking if the compression isn't too low with the de pistons, that this would help me hook up off boost then when boost finally comes in it'll be all good. And if torque drops a little low it wouldn't be too bad cause I can take advantage of the 4.11 gears to compensate for the loss of torque at the start.
Does all this jiberish make sense??? :confused:
TrunkMonkey
Car: 2000 Lincoln Navigator
iirc, your compression would drop to 7:1.
unless you're shooting for some very big numbers with very big boost, there's absolutely no reason to drop this low.
-demetrius
Calesta
Eh, it'll be driveable. We had a Subaru RX here for a while, and the stock compression ratio on that engine was only 7.4:1. It had a small turbo that boosted only 5psi, and it wasn't super duper fast to spool either, but it was very driveable off boost.
If you want to run compression that low, you can do it- but to really take advantage of it, you'll want to boost enough to need aftermarket pistons. The power levels you could get with a static compression that low on pump gas would probably kill a set of OEM cast pistons in no time.
fo0manchu
wow... 7:1 is too low, i'll just keep the kae pistons. I'm only aiming for about 220hp at the wheels. That much power in a datsun 510 equals lots of fun!!:ylsuper
Chingon
Car: 1991 and 1992 hatchbacks
i thought de pistons were highe comp.
rco8786
Chingon wrote:i thought de pistons were highe comp.
DE pistons in an E drops compression.
Chingon
so I take it ppl use these for boost? Or do they stay with the same pistons? Or just go aftermarket forged?
