Indeed you are right, and i found out a little later and just didnt post back..at first I wasnt actually threading the threads into the part that bolts onto the hub, but problem is solved now , now the only problem is i need an alignment.Kouks wrote:LMAO...if these are true coilovers not sleeve overs, then you need to turn the bottom mount towards the right to make your coilovers overall height shorter. This makes your car lower..........
