How low can I go with D2 coilovers on my M45S!!
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Expecting my D2 coilovers this week and I really want to ride low for a while!! Even if it means ride low and slow!! Lol!! If anyone can help from personal experience or from friends you know with these coilovers... I'm rolling on 20" wheels with the eibach pro kit and although my front end was sitting nice over the tires the rear had too much gap IMO! If you have pictures showing your stance at said height it would be appreciated!! Thanks!
06M4.5
Car: 2006 M45
This all depends on what size wheels & tires your running, most important is your off-set.
With my sey up my M is about 26" from ground to all 4 fender lips. Keep in mind this is with 245/285 tire (20" wheels).
If your running 245/275 try setting them at 25.5"
You have to adjust the coilovers to your set up, every set up is different.
The Bodyguard
Yes, I figured every wheel set up would make a bit of difference... I am on the 245/ 275 set up. 20"x9" +35 20"x10" +35 wheels! I am considering camber for a while as I am attempting to gain a VIP look!! Eventually would like to roll flush and slammed not cambered since this is my daily until I decide to buy something. Thanks for your input, these will go on as soon as they arrive!! :dblthumb:
mexillis
Car: M45s
main factor will be the roads in your area and where you normally drive. If you have big speed bumps or dips on the the highway or wherever you go that will set your height to go off of.
06M4.5
Car: 2006 M45
20x10 with et35 wheel will stick out of the rear fender but the lower you go the more you'll tuck the tire.
Start by installing the coilovers first, get the car to sit as you like it.
Play with the camber last as this may give you the clearance (if needed) you need.
If your wheels still sticks out you may be able to mill 3 or 4mm off the back of the wheel. You don't want the wheel to hit the fender lip :nono:
Also keep in-mind the lower you go the stiff the ride must (front) be.
I would tell you to adjust the rear to about 20 clicks, front around 30.
I have my M set at 16 rear with 27 front. I"ll be going to 20 on the rear next time I take the coils off.
06M4.5
Car: 2006 M45
I forgot, make sure your gas tank is full. :)
kermit the guy
Car: 2008 infinity M35 Sport
you dont want to go to low on the fronts , your catz are gonna hit any and every little thing , unless you dont mind not parking in certain areas or going out of your way just to go around the whole mall just to get in another way because of speed bumps ! ha ha! its all up to you , alot of people dont care if they scrape all the time , i know i do , mine are set at 25.5 in the fronts and 24.5 in the rears i barely make it over low speed bumps! once i change out my catz , thats when im gonna go a little bit , just a tad lower ! good luck and have fun driving like me , i drive like im on the track bobbin and weavin ! ha ha ha!
The Bodyguard
Thanks for the advice! Full tank of gas, got it! I plan on riding low so I've been checking for the best route possible where I go daily... Also, want Berks HFC to help with the scrapping... As far as my rear sticking out at 20"x10" +35 doesn't look like a problem right now but I'll play with the camber as best I can...
Thanks again guys ! :dblthumb:
kermit the guy
it will tuck in !, my old rim was the same as yours and i was tuckin !
The Bodyguard
kermit the guy wrote:it will tuck in !, my old rim was the same as yours and i was tuckin !
Nice!! That's what I'm hoping for!! :dblthumb:
The Bodyguard
Ok d2 coilovers install done couple days ago... Came back to Shop today for final tweaking and more low up front after letting them settle, now a hand wash and pics up later tonight... My wheels ARE tucking now!! Nice, extremely satisfied with the results!!
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
:dblthumb: can't wait to see the finished product...
were lowered on Eibachs before?? can't remember..
The Bodyguard
Yes, eibach before...working progress!!
CPJ LB
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
can't remember if you sold the eibachs or not....I may be interested... :biggrin:
The Bodyguard
CPJ LB wrote:can't remember if you sold the eibachs or not....I may be interested... :biggrin:
Check my post... They are spoken for until the end of the month at that point they should be sold a I'm letting them go for $110 shipped!!
The Bodyguard
A couple pics of the finished product!!
kermit the guy
cars lookin good ! , whats the height front n back on yours?
im pretty low as well , but i want to go lower in front but i scrape already on little dips or uneven roads ! ha ha
mexillis
Car: M45s
^ where are some pics of ur ride?
The Bodyguard
kermit the guy wrote:cars lookin good ! , whats the height front n back on yours?
I don't know exact height but tension/dampening is at 14 rear 16 front...firm no scraping no bouncing.. Smooth! I like this ride... :dblthumb:
kermit the guy
mexillis - you got me i dont have an M !! ha ha i keep forgetting , iil try to post it when i get home ! this is what happens when you get OLD like me ! ha ha!
06M4.5
Car: 2006 M45
now you need to take it on the highway and do some testing (xxx mph) to really see if you don't scrape, I would set the front higher :biggrin:
How many inches are you dropped (ground to fender lip)? and what size tire are you running?
The Bodyguard
I'll check and post later... I daily my M so hwy and city all the time its all good!! Low but no scraping... :dblthumb:
The Bodyguard
Height on the front directly under license plate is 5", on the side in front of tire I'm at 4.5"... Rear from the side on front of tire I'm at 5.5" rear from the side behind the tire I'm at 8"... The rear bumper sits high as it is... :gotme
Its actually VERY LOW!! :dblthumb:
06M4.5
Car: 2006 M45
Most go by the ground to fender lip.
I'm at 26" for now with 245/285
zags
Car: '09 M35s "all black everything"
06M4.5 wrote:Most go by the ground to fender lip.
what would be the respective number settings for that height.
if I recall I think you said roads where you are bad, right?
same here in LA if so, I'm hoping when I go the CO route I can go lower than the HTs I had and still have good ride quality and not fret too much about scrapping/potholes etc
The Bodyguard
Ok.my bad... I'll check it like that tomorrow and post up... It's late now and getting ready for bed.. Gotta be up at 2:30am...
06M4.5
Car: 2006 M45
We have really bad street in my town, if you drive really slow with my full size tire it's ok at 26". I think I like it better at 26.25"
When we take long trips (4 people in the car) on the highway the car feels great but as soon as you start going over 80mph the small dips feel like big dip. Having only 2 to 4" space under the car that is over 4,000lbs is not great.
I think I may go back to 26.25" as when I'm by myself I have gone around 142mph with no problems, just run out of room to go faster.
I'm looking for that magic number that the car will look good, keep up with family (4 people) without problems and when I have a chance i can still enjoy my high mph runs(xxx).
Can I go lower even with my big tires? sure I can
Would it be safe? only until something happens
HT's gives you just a little more than 1 finger gap at all corners, CO's will let your fender lips be even with the top of the tire and still have a nice ride. When the time comes to go to shows you can drop it even more to a point that the fender lip is even with the wheel lip or even more but won't be drivable.
If your looking to be really low and would like to be slammmmed when parked you may want to look in to an air-ride system.
The Bodyguard
Ok, measured the right way and I'm LOOOW.... and even 25.25" both front and back!!
Tires are 245/35/20" front and 275/30/20" rear!! Rolling nice!! The stance is sick in person... Tires are tucking about an inch all around!! :dblthumb:
mexillis
Car: M45s
Have you tried driving over any speed bumps yet? Lol
06M4.5
Car: 2006 M45
Also when you have a chance look under the car while in front of the bumper. Most will tell you that the cats do all the scraping but what has me scared is the front sway bar.
I hate when I have to drive over raised man-holes. :ohno:
On top of the sway bar is the oil pan.
Have fun but be safe.
