Hey rayjgold, I can't add much more than what's already been posted here...what specifically are you confused about? The temperatures of particular concern here are in the -20 to -30 F range.... I think Nick568's comments are right-on...rayjgold wrote:ok Im all confused now! It has been snowing a lot here and the temp is about 10-30F . I be in a rush in the morning and im not sure if I even wait a minute to drive off! but i do take it slow......by the time i go about 5-7 blocks the car is warm enough to heat the inside(when the temp control on Auto it doesn't start blowing until there is warm air to blow or until the cold-hot level has moved to the hot side a little. Am I doing something wrong? should i be waiting longer?!??!?!
If the car is not moving, you are not warming up the CVT, only the engine. So, if you want to protect the CVT, no need to wait, just drive slowly at first for a few minutes in order for the CVT to warm up a bit.Jostudly wrote:I hear different answers on this question so I would like to know how long you should leave the Rogue idling on cold starts before driving it? I want to make sure I do not damage any of the moving parts in the CVT. I have read all you need is 30 secs to get the oil moving around freely; to people leaving their car on for 15 mins mainly for comfort in the car and to defrost the windows. I have also been thinking of getting a remote car starter but do not want to run into any issues down the road with electrical problems. Let me know your thoughts on this.
You are doing the right thing: By moving you are warming the car faster than those who let it idle.rayjgold wrote:ok Im all confused now! It has been snowing a lot here and the temp is about 10-30F . I be in a rush in the morning and im not sure if I even wait a minute to drive off! but i do take it slow......by the time i go about 5-7 blocks the car is warm enough to heat the inside(when the temp control on Auto it doesn't start blowing until there is warm air to blow or until the cold-hot level has moved to the hot side a little. Am I doing something wrong? should i be waiting longer?!??!?!
Ive read many issues with that in this forum....I use to want one as well and decided against it. First.....after you remote start the car, you have to press the brake and turn the car off and then turn it back on again!Jostudly wrote:Okay I thought there would be a lot of posts on this topic but getting back to my original post has anyone had any issues with a remote car starter on the Rogue?
Just a correction. You don't need a key to be place inside the car to get the remote start working. You only needs it if you want to remote start the car without the need to stepping on the brake and kill the engine.rayjgold wrote:Ive read many issues with that in this forum....I use to want one as well and decided against it. First.....after you remote start the car, you have to press the brake and turn the car off and then turn it back on again!
Second, you have to permanently plant a key in the car for it to even start remotely.....assuming you have the intel. key.
I'm not familiar with the ProStart system so I cannot say what it will do. Read the manual if you can get one.Jostudly wrote:I do not have the intellikey as I only have the S model. I never heard that you need to step on the brake and turn it off and on again to get it to start. I was looking at getting the Pro Start from Canadian Tire.
Ok, here is how it is explained to me as well as my last vehicle had remote start.Jostudly wrote:Okay so just so I get this straight in order to drive the car you start it with the remote. Then you unlock you door and have to put on the brake in order to start with the key? If this is for all car starters I will probably not get one.
All command starts work pretty much the same. Remember that when you push the command "start" button, there is no key in the ignition, so of course when you arrive at your vehicle you're going to have to insert your key and turn it to "on" before driving away.Jostudly wrote:Okay so just so I get this straight in order to drive the car you start it with the remote. Then you unlock you door and have to put on the brake in order to start with the key? If this is for all car starters I will probably not get one.
I was only talking about the intel. key. If you have the regular turn-the-key-to-start-the-car version, then it should work just as well as any other car if it is installed correctly.Jostudly wrote:Okay so just so I get this straight in order to drive the car you start it with the remote. Then you unlock you door and have to put on the brake in order to start with the key? If this is for all car starters I will probably not get one.
