Thanks for your input. I went outside and plugged it back in. My question now, is revolution sensor is the VSS(speed sensor) or the TPS (Throttle Position Sensor) What is the Revolution sensor? The person wrote its like the governor for the transmission. When you unplug E13 the shifting problem goes away between 1st and 2nd gear.
People spoke of changing the trans fluid or even replacing their trans and still having the same problem. E13 is what on the wiring diagram? I have that 240sx directory but not finding what E13 is.
I appreciate your help and further if needed, or anyone else reading this post.
Modified by cellogig at 5:34 AM 2/1/2008
