Bosch brand I happen to get at Pep Boys , Ltd Lifetime wty ,@ 145kmi original tapped out. Car now has 270k and NO alternator issues - but I check tension and clean pulleys and belts yearly .
On mine and many Infinitis it's a VERY small diameter alt. pully run by a fairly large crank pulley , so there can be squealing at startup when it quickly hits high idle. Ya gotta be in a "narrow" margin of tension , too much DOES burden the front bearings on cold start ( IF there is not really ANY opposing belt 180 deg across!!) .A lot of tension of course = bad for the Alternator.
So I've gone the route of very ,very little belt dressing on a piece of terry-cloth rubbed onto cleaned up belt.
I learned never to spray belt dressing heavy near ANY alternator, gets sucked inside - apply w/rag - 'cause spray FRYS the bearings cause chemical enhances ALL "dressed" surface friction . Since I use so little , I don't experience any negative "belt softening/breakdown" we've all heard as objection to belt-ease products - when squeeling stops - I'm good.
Ya got a serpentine belt ? Never mind
