BuudWeizErr »
https://forums.nicoclub.com/buudweizerr-u1639.html
Fri Apr 18, 2003 8:49 am
I've heard the 5-50-500 breakin recommended, thats what I did. Good stuff.
Start it, drive 5 miles, go back and check everything. If something is wrong with it, it should become apparent by then. Then drive it 50 miles, change the oil, and check everything once more. Then drive it 500 miles, change the oil, and check it again. If everything is ok, then you have a good motor and you can proceed destroying it.
