How long can gas sit for?
sbird1
Car: 2006 BMW 325i
Anyone know? My Z has been sitting for a little over a year. I just want to know if, when I get my engine in, starting will hurt it. Should I drain the fuel or will it be Ok?
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
I'd drain it just to be safe
tg
I put some fuel line cleaner mixed with ethanol gas in the tank before and shook the car back and forth to stir it up, then just pulled the hose off the fuel filter (not on the engine side) , attached a 4' length of fuel hose with a male-male joint leading to a plastic gas tank, jumped the fuel pump relay and let it drain itself into the bucket --- once you've emptied the tank, put in another 2-3 gallons and flush it through then fill it up enough to get to the gas station and fill 'er up with some 94.
or you could just top it up with some race gas to bring the octane back to a normal level, then change your fuel filter after you burn through that tank just to be safe.
sbird1
Car: 2006 BMW 325i
That makes me sad... the gauge registers a full tank.
Wetmyson
Car: Z32
tg wrote:I put some fuel line cleaner mixed with ethanol gas in the tank before and shook the car back and forth to stir it up, then just pulled the hose off the fuel filter (not on the engine side) , attached a 4' length of fuel hose with a male-male joint leading to a plastic gas tank, jumped the fuel pump relay and let it drain itself into the bucket --- once you've emptied the tank, put in another 2-3 gallons and flush it through then fill it up enough to get to the gas station and fill 'er up with some 94.
why 94 octane? why not 91,92,93? just curious
skitz047
Car: 1992 300zx N/A
Well when i bought my z off the guy he hadn't driven it in forever but it worked fine. But i doubt it was a year, a couple of months maybe. The weird thing was that when i took the cap off, it was like pressurized inside. It let off a pretty loud hissing noise. It was weird, haha
nsrZ32
78 Datsun 280Z
01 Ford Focus S2
Wetmyson wrote:why 94 octane? why not 91,92,93? just curious
The higher the octane the better. I only use 93 or 94.
skitz047 wrote:The weird thing was that when i took the cap off, it was like pressurized inside. It let off a pretty loud hissing noise. It was weird, haha
My car does that every single time I remove the fuel cap
96SoftTop
Car: 1996 300ZX Convertible
nsrZ32 wrote:The higher the octane the better. I only use 93 or 94.
But, Octane inhibits combustion. That is necessary in a high compression, TT engine. I don't think it does any good for a car that doesn't need it! High Octane does nothing to increase power or efficiency. It only makes sure that the gas doesn't burn before the spark.
Besides, you can't get any higher than 92 Octane where I live!
Ken
