I was thinking along the same lines, but just don't feel like looking up the physics which I've long since displaced.Towncivilian wrote:...An LED draws very little power, so I'd imagine a typical battery could power a single LED for days without a problem.
Not quite. Watts = Volts*Current, so Current = Watts/Volts = 5/12 = 0.416666... Amps.QX4ME wrote:5 Watt bulb on 12 V battery draw ~ 0.5 Amp. If a battery is rated 100Ah, then it can run 200 hours (just based on 100Ah definition). I am not sure how they claim 100Ah. Does it mean after 100Ah 12V starts to drop, or 12V goes down to half?
Good points. The desk lamp is 12V DC, there is an inverter it plugs into which plugs into household AC (at least the stickers and such attached to it say so).BubbaFL wrote:Keep in mind, if you're using an inverter to run that desk lamp, the inverter by itself will probably draw five or ten watts (and could be more if it's a larger unit).
Best to get a light designed to run off of 12 volts. The second best option would be a USB-powered light, and a 12v-to-USB adapter.
Also, in my QX4 the key has to be in the accessory position for the lighter outlets to work, which means other accessories are energized and there is more load on the battery. If yours is the same, you'll have to directly wire your light to the battery to avoid this.
Easier to just buy a solar-powered rechargeable lantern...
--Thanks for the info! Appreciate it!Chuck Tribolet wrote:Not quite. Watts = Volts*Current, so Current = Watts/Volts = 5/12 = 0.416666... Amps.QX4ME wrote:5 Watt bulb on 12 V battery draw ~ 0.5 Amp. If a battery is rated 100Ah, then it can run 200 hours (just based on 100Ah definition). I am not sure how they claim 100Ah. Does it mean after 100Ah 12V starts to drop, or 12V goes down to half?
And I think 100AH is on the high side.
If it runs on 12V DC, that's a power supply (AC to DC) not an inverter (DC to AC).Camelfilter wrote:Good points. The desk lamp is 12V DC, there is an inverter it plugs into which plugs into household AC (at least the stickers and such attached to it say so).
- & great idea about direct wire to the battery!
Make sure you put a fuse inline, on the positive side, as close to the battery as possible.Camelfilter wrote:BubbaFL wrote:K
Great idea-thanks! I think I have a 12gauge inline fuse lying around somewhere.BubbaFL wrote: Make sure you put a fuse inline, on the positive side, as close to the battery as possible.
