How long are the 240sx's wheel studs?
ztommyx
stock?
they are 12mmx1.25 but how long are they?
just replacing a couple stripped studs and want to know if i should get extended studs for future added spacers.
thanks!
edwinS13
Car: 1989 nissan 240sx s13 fastback
you should just get stock and, later on if you need spacing, just get the spacer that has the studs to extend the length....sorry my post was no help, but i tried
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
get the nissan quest wheel studs they are 15mm longer over stock. and like 2.49 a piece
edwinS13
you dont need any modification for that, can you just slap those on and then some spacers? i would hella do that
martins_240sx
yes they are the same excepth 15mm longer. Just go to autozone or kragen etc and ask for a 240 wheel stud and a nissan quest wheel stud. you will see the quest is the exact same except its longer
khmer1
uh im also looks for extended studs for my 240sx what year quest
martins_240sx
pick a year....Im not sure when they came out but they are probably all the same...ask for a 240 one and a quest one. interlock the threads( they should interweave perfectly and if they do your golden like a shower)
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
Infiniti J30 studs work as well. Same length as the Nissan Quest studs.
