Actually, no... when I sat in the driver's seat and then nearly broke my neck trying to get out because the roof rail is so low on the Yaris, I never got back in one ever again.Xtrykr wrote:Ever driven a Yaris? Now that POS will have u wishing for an emergency eject seat button!
I doubt it actually increased that much.TheRussianBull wrote:Yea my stability improved alot i got 7.5 wides and it has increased the stability although my car is higher cus of the rims being 17" lol... but ima drop it ASAP
The only way going to 17" rims would make your car taller is if you chose the wrong tires. If you choose the RIGHT sized tires, your OD is the same as it was with the stock tires, hence your ride height will be the same.TheRussianBull wrote:Yea my stability improved alot i got 7.5 wides and it has increased the stability although my car is higher cus of the rims being 17" lol... but ima drop it ASAP
Thsts what I meant. But still there can be a difference of 3-5mm, thats why I wrote "I doubt it actually increased that much"Ever Victorious wrote:
Remember, the 17" is the diameter of the rim, not the tire.
