Willerton »
https://forums.nicoclub.com/willerton-u97388.html
Wed Oct 01, 2008 5:32 pm
I find it hard to shift smoothly. I've driven 3 and they are all the same.I thought it was my lack of recent experience with a manual trans, butdrove a different car and it was fine.
It seems that the throttle needs a stiffer return spring. The RPM doesnot lower very much when you let off the gas and put in the clutch.Had the dealer check it and he said it was in spec.
That said, the car is still a joy to drive. It has significantly more powerthan the CVT models. The 6th is more like 5th in other cars, maybelower. It does rev high at 60mph on the highway. I don't find it to betoo distracting. (I have the really great stereo, though.) I do noticethat since there is so much power and torque, you don't have to shift it very much. All the speeds I have to drive are very well matchedto a gear. I find that you really have to mat the clutch to make sure theshifts are as good as possible. Good practice, but lots of cars willallow proper shifting with the clutch a little bit off the floor.
