Ligouri Rd wrote:-that is exactly why you get better gas mileage in the Z. Lower rpm means less gas burned, each cycle burns a specific amount of gas, less cycles = less gas. The larger displacement should require a slighly larger amount of gas but if the torque is so much greater that it can turn a much lower rpm you will get better gas milage. By the way, if they are turning a different rpm and running at the same speed they are either not geared the same or automatic. Tires are a part of the gearing too ya know.
Back in the day with the ole suburban the base model came with a 5L v8 and my silverado had a 5.7L. The larger motor got slighly better gas milage because it had the more torque to move the car at a lower rpm. Vette's (pre '06) got pretty good gas milage because at cruise the engine is pretty much sitting at idle.
You're semi-right about how the operating range of an engine affects gas milage. Power is what determines the amount of gas you burn, not torque. Torque is essentially the amount of gas you burn per cycle of the engine, so obviously if you burn half the gas per cycle (half the torque) at double the RPM, your gas consumption will be the same (in a perfect world), and so is your horsepower.
However, that's in a perfect world. In a non-perfect world such as ours, your engine losses scale with engine speed, so the engine going twice as fast is less efficient because of friction, ring drag, reciprocating losses, etc.
