AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Wed Jun 01, 2016 5:58 pm
The valve body, to my knowledge, is a major component of the unit. As such, they'd likely just replace the whole thing.
[And yes, I believe the codes pointing to the cam sensor issues are secondary to the CVT problem. Plan on replacing both cam sensors (they're not expensive). Besides, if your CVT is shot, you really don't need to worry about the cam sensors until it's fixed.]
All CVT transmissions from 03 to 10 got a warranty extension of 10 years or 120k miles. Did you check the transmission fluid level?
Reading back through your first post, I'm concerned about the water statement. How deep is deep? If you submerged the CVT vent or got water in a harness or solenoid connector, who knows what kind of havoc could have occurred...
Possible causes of the CVT code are:
- Pressure Control Solenoid Valve 'B' (secondary pressure solenoid valve) system
- Control Solenoid Valve 'B' harness is open or shorted
- Control Solenoid Valve 'B' circuit poor electrical connection
- Transmission Pressure Sensor 'A' (secondary pressure sensor)
- Line pressure control system
Those can be due to a faulty transmission, low coolant, low fluid, bad solenoid(s) or damage to the harness - possibly by water. The diagnostic process in the FSM is lengthy, and requires a Consult-II to perform:
DTC P0868 SECONDARY PRESSURE DOWN
The pressure control solenoid valve B (secondary pressure solenoid valve) regulates the secondary pressure to suit the driving condition in response to a signal sent from the TCM.
This is not an OBD-II self-diagnostic item.
Diagnostic trouble code “SEC/PRESS DOWN” with CONSULT-II is detected when secondary fluid pressure is too low compared with the commanded value while driving.
Possible Cause
Harness or connectors (Solenoid circuit is open or shorted.)
Pressure control solenoid valve B (Secondary pressure solenoid valve) system
Transmission fluid pressure sensor A (Secondary pressure sensor)
DTC Confirmation Procedure ACS002U1
CAUTION:
Always drive vehicle at a safe speed.
Be careful not to rev engine into the red zone on the tachometer.
NOTE:
If “DTC Confirmation Procedure” has been previously performed, always turn ignition switch OFF and wait at least 5 seconds before performing the next test.
After the repair, perform the following procedure to confirm the malfunction is eliminated.
WITH CONSULT-II
1. Turn ignition switch ON and select “DATA MONITOR” mode for “TRANSMISSION” with CONSULT-II.
2. Make sure that output voltage of CVT fluid temperature sensoris within the range below.
FLUID TEMP SEN: 1.0 - 2.0V
If out of range, drive the vehicle to decrease the voltage (warm up the fluid) or stop engine to increase the voltage (cool down the fluid)
3. Start engine and maintain the following conditions for at least 10
consecutive seconds.
VEHICLE SPEED (accelerate slowly): 0 → 50 km/h (31 MPH)
ACC PEDAL OPEN: 0.5/8 - 1.0/8
Selector lever: D position
4. If DTC is detected, go to CVT-151, "Diagnostic Procedure" .
1. CHECK INPUT SIGNAL With CONSULT-II
1. Start engine.
2. Select “MAIN SIGNALS” in “DATA MONITOR” mode for “TRANSMISSION” with CONSULT-II.
3. Start vehicle and read out the value of “SEC PRESS”.
OK or NG
OK >> GO TO 5.
NG >> GO TO 2.
2. CHECK LINE PRESSURE
Perform line pressure test. Refer to CVT-42, "LINE PRESSURE TEST" .
OK or NG
OK >> GO TO 3.
NG >> Repair or replace damaged parts. Refer to CVT-43, "Judgement of Line Pressure Test" .
3. DETECT MALFUNCTIONING ITEM
Check the following:
Pressure control solenoid valve B (Secondary pressure solenoid valve). Refer to CVT-131, "Component
Inspection" .
Pressure control solenoid valve A (Line pressure solenoid valve). Refer to CVT-120, "Component Inspection"
OK or NG
OK >> GO TO 4.
4. CHECK TRANSMISSION FLUID PRESSURE SENSOR A (SECONDARY PRESSURE SENSOR) SYSTEM
Check transmission fluid pressure sensor A (secondary pressure sensor) system. Refer to CVT-137, "DTC
P0840 TRANSMISSION FLUID PRESSURE SENSOR A CIRCUIT (SEC PRESSURE SENSOR)" .
OK or NG
OK >> GO TO 5.
5. DETECT MALFUNCTIONING ITEM
Power supply and ground circuit for TCM. Refer to CVT-154, "Wiring Diagram — CVT — POWER" .
The TCM pin terminals for damage or loose connection with harness connector.
OK or NG
OK >> GO TO 6.
6. CHECK DTC
Perform “DTC Confirmation Procedure”. Refer to CVT-150, "DTC Confirmation Procedure" .
OK or NG
OK >> INSPECTION END
NG >> Replace the transaxle assembly. Refer to CVT-224, "Removal and Installation" .
