welcome to Nico. You must step on your brake a lot for it to have burned out already! jkjk.
check this thread, in the begining it explains how to remove the brakelight.
zerothread?id=255315
also take a look around the forum, there are lots of threads to help you, above is the search button, and a lot can be found, just click the dropdown and search the VERSA forum only if it is Versa related. Also check the main portal for a lot of info and how tos!
NissanVersa.org
