1dollar240 »
https://forums.nicoclub.com/1dollar240-u221.html
Wed Mar 19, 2003 11:35 pm
Not many people torque lugnuts, but when it comes to suspension/head bolts/ bellhousing bolts/ flywheel bolts/ other misc important shizzit, then yes, use a torque wrench. Some one said that over torquing a bolt can stretch it, causing it to fail, this is very true. But on the other hand, some bolts (head bolts) are designed to be stretched (known as torque to yield bolts). Bottom line, use a torque wrench, it will save you time and money in the long run.
Brett
