my car is pathfinder 2001 3.5 v6
i little know english and sorry pplz
this is my map sensor
this is my map sensorthis is Mass Air Flow and i wont BOOST SENSOR (MAP) I have MAF and MAP sensors... when i chek my car in comp the problem was VACUUMTowncivilian wrote:You don't have a MAP sensor, you have a MAF sensor. The part pictured is also not the correct part.
You can use part 22680-2Y001 which is a Maxima MAF, but has been proven to work fine on Pathfinders. At ~$90 for an OEM part, it's a good price vs. the $400+ for a new OEM R50 MAF.
I have not installed a Maxima MAF personally, so I don't know the specifics on installation of that part. And since you say you don't have a MAF sensor, you will not need anything specific for installation I believe (the MAF sensor is originally secured by two tamper-resistant T20 Torx bits).
Okay, the SENSOR-BOOST, aka [22365] EGR VACUUM CONTROL VALVE, is around $130. Your pictured part looks okay as well. I don't know where this sensor is on our engine, though. I will look for it next time my hood is open if I remember.kukii2 wrote:this is Mass Air Flow and i wont BOOST SENSOR (MAP) I have MAF and MAP sensors... when i chek my car in comp the problem was VACUUMTowncivilian wrote:You don't have a MAP sensor, you have a MAF sensor. The part pictured is also not the correct part.
Sorry, could you explain a bit better? I'm unable to find the part using the exploded parts diagram.kukii2 wrote:This sensor is near whell where is computure,plz take a picture
