How hot under the hood??
spitz7985
Car: HICAS S13
Is 300 degree hosing good enough for under the hood? Or should I buy the 500 degree stuff?
Edit: It will be used as IC piping.
Shift_Oversteer
Car: s13 convertible
your car should run at about 180-240 tops so thatll be fine
spitz7985
Car: HICAS S13
Well thats the engine temp, but I would imagine that under the hood it is hotter because of the exhaust.
i2ice4m3
Car: COUNTERSTRIKE!
i would think the opposite since the heat source is the engine itself
rico05
Car: 1992 RMS13 w/ CA18DET
For use right on the turbo (ie hot pipe couplings etc) get the highest temp rating you can. Turbos get HOT. Under hood ambient temps get super high. I love working on my car after I warm it up here in the lovely Texas heat.
spitz7985
Car: HICAS S13
i2ice4m3, I have no idea what you are talking about.
I ordered the 500 degree stuff. Better safe then sorry. Thanks guys.
whiterps13
Car: white LE hatch
good choice. it would suck to have to replace melted hosing, plus the risk of an engine fire ;[
