Bluefire wrote:Well when your tracking your car you will run hot. It is really common to be running in 100C range. But this is what I have on my car or will be going on in the near future. Short of going v-mount
1: Custom dual-pass radiator (I hate my koyo!!!)2: Shrouded puller fans3: radiator shrouding (Need to direct that air into the radiator, not around it)4: Vented hood5: Oil Cooler6: Manifold, Turbo, Downpipe shielding
etc.. etc..
-Bluefire
exactly what im running, minus the oil cooler. (but using the stock one if that counts )
im was just about to go somewhat of a V, but i decided to do a lil bit more ducting and see how it holds at the next event. just cause i realized the last event was about as hot as it would ever get and the engine did pretty good.
240z4u, good info to know.
