mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Tue Jun 19, 2007 7:48 pm
It should fit in there but would definitely take some time, money, and likely a good deal of fabrication. The hardest part of it all would likely be the electronics. The VQ has an OBDII system, which is not only a pain as far as performance modifications but requires a lot more electronics than the OBDI setups (basically more sensors). You could go with an aftermarket ecu setup, which would definitely help in the wiring area but I don't know a whole lot about what is available for the VQ's.
Personally, if you're willing to invest the time, money, and work required to do that swap I would actually put all of that into working on the VG. VG's definitely are weak normally aspirated but with a turbo setup they can be monsters. 400-500 whp on stock internals is not uncommon and isn't really all that hard to achieve.
There are quite a few ECU options out there that are easy to setup with the Maxima. The easiest route for the exhaust manifolds, in my opinion, would be to use two 85-88 Maxima or 84-89 right/rear manifolds. These curve around the back of the engine to a crossover pipe. From there, you just need to have a custom crossover pipe made with a turbo flange to bolt the turbo on. This allows you to have a lot of room to put the turbo where you want it. Probably the thing to do would be to relocate the battery to the trunk and have the turbo sitting around that location. This allows you to route the intake piping into the fender for a "cold air" setup as well as being able to run your aftercooler piping through there as well.
For an absolute basic setup using salvage/used parts and some new parts, I could build a setup for $1k to $1.5K (this is what I did to mine to start). For a good looking setup with some decent used and new parts I think you could easily have a 300+ hp setup in the $2.5k range.
If you'd be interested in taking that route I can give you a good list of things to look for to start.
