yellow_jacket »
https://forums.nicoclub.com/yellow-jacket-u4236.html
Fri Nov 28, 2003 8:12 am
The only way you wouldn't save is if you had to pay someone to set the backlash. You already bought the thing for $120. Fluids will be about 20 if you go synthetic. Tube of RTV$3. The only thing I am not sure on is the shims.
Basically, the gears can't be too close or too far away from each other. Either one can cause serious damage. That is where the shims come in. Not real hard to do, just time consuming.
