How hard to convert manual windows/doors to power ?
Speed-Techniques
I have a power parts car, and manual car, wanted to know what I need to convert... basically, is the window "frames" the same ? do I just need the panels ? thanks !!
Luke
red93_240
Car: 93 nissan 240sx
the window "frame" should be the same.....just a question but why do you want to switch to power...its a nice luxury but it makes the door heavier......
Speed-Techniques
I'm about 6'1 and the crank hits my knee, and I hate having to reach across to lock/unlock the doors, or roll down the passenger side windows etc etc...
I'm lazy -- but oddly willing to work so i can be lazy... paradox?
thanks man !
red93_240
no prob.....i know how you feel i'm 6'2 and not very thin at allso i know exactly what you mean....
Ladybug
i'm 5'4, i have to get out of the shoulder harness to lean AAAAAAAAAAAAAAAALLL the way over to touch the manual handle....i use my nails to roll it down an inch or so ;)
BoyWonder
Car: '93 Nissan 240SX S13 Convertible (reclaimed... wootles)
I'm 6'4".. if I don't get frequent haircuts, there are clearence issues in my S14. Thankfully, I have power everything :D
Speed-Techniques
bump this still need an answer
BoyWonder
What kind of car? and, maybe this should be under a car specific general or technical forum?
Speed-Techniques
90 hatch, had no power, I transferred all the guts out of a power door. There is no wiring in place to hook up to however.
BoyWonder
I'd imagine you'd have to run some wiring to an extent. May want to invest in a FSM or something to see what goes where exactly. The other option is to find someone who has power options and use them as a blueprint. I'd just get the FSM, though. Sorry I can't help more, but I haven't done it myself..
MikeMurphy
Car: Guess
Grab and FSM and do it. I cant imagine it to be complicated at all, especially if you have a donor car right there.
Think of this as an opportunity to do a better-than-stock install and setup.
While your at it, if you plan on installing an alarm and want LEDs on your doors, its a good time to do it.
tonynalli
the panels are the same they are the same for the auto and the hand crank windows. you will have to find power to send to the motors. there is to my knoledge one empty slot on the fuse box under the dash that you can piggy back power off. but you have to do that to both doors. and thats where it gets trickey. but jsut do some tinkering. make sure you use thick gauge wires for it though. just cause it looks the same size on the outsdie it doenst mean that its the same on the inside.
Speed-Techniques
I wouldn't reccommend this install to anyone, I'm still working on it.... it's a MAJOR PITA !!
sigh...
yozsi
Car: Racing
why would you want to convert, nissan power regulators suck serious arse. they are a cable link type set up that always breaks. plus, if one of those little plastic pulleys break you have to replace the whole regulator.
aspinballer
Car: 1995 240sx
I recently installed a new passenger door on my 95 and had to transfer my power locks to the new door and it wasnt very difficult, took me only about 35 minutes, plus i had to exchange the wiring harnesses, really wasnt too bad, all i did was remove the entire latch, take the unit inside to rig up and the replace.as for the windows, i sympatize
tonynalli
all it takes is a little common sence to do and some time. when you own a nissan you know that you will have to put some time into it.
DGA
Car: Cars
Just make sure that you wire everything correctly to the fuse box, and you should be ok.
tonynalli
if you have the fuse splitters then you wont need to put them on the fuse box. but that takes more sence than the average person has to do it.
Speed-Techniques
this is starting to turn into a me = retard thread ?
by the way, senSe, not sence....
tonynalli
changing them is no simple task. you will have to have some time on your hands and a little bit of money. and some wires....
Speed-Techniques
why can't i just hijack the existing power lines?
tonynalli
if there are then do that. i never knew ther was any wires in the door panela
