How hard is to replace spark plugs?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
sweetaz
Car: Nissan Versa (Tiida)
below thread says http://forums.nissanversa.org/zerothread/381175
To change these plugs, you need to drain the coolant, remove the intake manifold and all four coils, and you will need a special plug socket (not sure of the size or make/part number). The service manual.
Is this true that the process is this difficult? especially draining the coolant part?
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
I don't remember the coolant part.
This thread has some info also...
http://forums.nissanversa.org/zerothread/456951
sweetaz
thanks for the help - Promised Land! I managed to download the Tiida/Versa service manual and found the above relevant pages.
On the instruction it says...1. Remove engine cover (1).2. Drain engine coolant. 3. Remove oil level gauge.4. Loosen and remove intake manifold (1) bolts (A) (B).
can i skip steps 2 and 3, and move from 1 to 4?
Disphunktion
Car: Nissan Versa
I didn't drain the coolant so you can skip the step.
conversation
Car: Versa 1.8 S HB
Sweetaz, Great pics! Thankyou. Hard to tell from looking how hard it will be. I have 90,000 miles to go, luckily.
Disphunktion
Car: Nissan Versa
When I looked at it, I b****ed like crazy because none of where the spark plug was. But once you're into it, it isn't that bad.
I just used a a snap-on plyer to block the coolant (in case) and that it.
Return to “Versa Technical Discussions”
