Thanks for providing the info from the manual. Very helpful. So, if you want to remove the pillar trim, you have to "cut clips". That's good know (I will need to buy some new clips before doing this method).
Regarding "pulling the rubber welt down", I'm not sure what you mean by this. I don't see any flexible rubber along the side (pillar).
Unfortunately, the power cable is pretty thick (at least from the picture). I don't want to over pry and break anything. I think I should plan on removing this trim.
