How hard is it to replace the antenna?
MattB
Car: 2001 Infiniti I30A
My G20's power antenna most likely needs a new motor (it screams). How hard is it to replace the assembly? Could I trust a good independent shop to do it right or should I take it to the dealer since it's an electrical part? Or is it so easy I could do it myself?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
With care, it is an easy DIY.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You need to search, I know ive posted how to more than once..
In summary, you take out the motor (easy), replace it, and then put in the mast (unless the whole assy comes with a mast).....
4 bolts holding on the motor.. Simple stuff!!!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:You need to search, I know ive posted how to more than once..
The trick is undoing the outer antenna retaining nut without scarring it.__________________Brian1995 Q45 & Q45t & 2000 Q45
Discover the power of the button!
elwesso
2007 BMW M Coupe
I was able to do it by putting a towel over a pair of channel locks to loosen it, and then unscrewing it by hand.
I now have mine in basically hand tight, its really snug though.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
OUCH! One slip, and it's time for a new chromed nut! Better use the correct wrench, or even a small single bit screwdriver verrrry carefully!
I recommend the wrench.__________________Brian1995 Q45 & Q45t & 2000 Q45
elwesso
2007 BMW M Coupe
On the Q there is the top part that is all chrome, and doesnt have a fitting. You take that off, and then the rest just goes down into the car.
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
A rubber strap wrench is very slick for removing the antenna nut, no scratches possible.
cweberj30t
Car: 1993 J30t
2003 G35
2007 G35X
2011 G37X
I removed the nut with a pair of needle nose pliers by sticking the two points into each side of the nut. You have to be real careful not to strip the ends off. It's an easy DIY especially if you are replacing the whole unit with a mast.
