How hard is it to remove the radiator in a 2003 V6?
Micallen
Car: 2003 Nissan Pathfinder SE 4x4 V6
I need to change belts, and it seems I would have a LOT more room if I removed the radiator.
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
Yes you will have more room BUT you do NOT need to remove the radiator to change the belts.
yeldogt
Car: 02 Pathfinder 4X LE (X2)
It's not a bad job ... get the OE Nissan belts. No more expensive and they are quiet. Especially the AC belt
jscricca
Car: 03 Pathfinder LE
The belts took me about 45 mins going pretty slow. The hardest part in my opinion is taking off the bottom splash tray which you will need to gain access from the bottom.
The only other difficult part is snaking the belt around the fan.
Micallen
jscricca wrote:
Mon Apr 23, 2018 4:10 pm
Sweet. I already have the splash guard removed (because it only had 3 bolts holding it on and was sagging). Guess I can make pretty quick work of it. :dblthumb:
Micallen
Followup, I changed the belts a few weeks ago. It was simple. Thanks.
yeldogt
Report back if you get any squeaks
