How hard is intake manifold install with engine in car?
jt15833
Car: 95' 240SX
I am waiting on lower intake - head gasket but I want to install the head in the car and get that taken care of.
Is it hard to install the entire intake (plenum + lower) to the head once the head is in the car?
Thanks
bentvalves
Car: 89 Silvia K's
nope not at all, so long as you have a decent assortment of tools to work with.
jt15833
Car: 95' 240SX
thx ks maybe I should just start emailing you my questions.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Some of the upper --> lower manifold bolts are a little tricky, but not hard by any means. I seem to remember the ones in the middle being a little bit of a pain, but its easy enough. I would remove all the manifold brace things beforehand, otherwise it will suck. The first time I did it I remember being surprised at how easy it was.
bentvalves
Car: 89 Silvia K's
I remember having to slide a 3/8 - 6" long extenstion inbetween a few of the runners, then clipping the 14mm socket on to the end in order to access a few of the bolts.
jt15833
Car: 95' 240SX
are you guys installing the intake (upper and lower) together to the engine? Or the lower to the engine, then the upper to the lower? I would like to keep upper and lower together, if possible.
bentvalves
Car: 89 Silvia K's
I did them one at a time, not to say you couldnt do it the other way however.....not sure though.
r34 gtr
I seen to remember having to remove the upper, then the lower, because some of the bolts from the lower manifold to the head are impossible to reach with the bolts from the upper to lower manifold still in place.
