freakonaleash1187 »
https://forums.nicoclub.com/freakonaleash1187-u12997.html
Thu May 17, 2007 7:40 pm
Say you got a cheap N/A for $2k. If you go with a front clip (which is the easiest way), that will be about another $3k, and if you get a Z for $2k, the body will definitely not be in very good condition, so you would have to throw money at the body, and then you will spend a lot of money doing basic maint. items to the front clip. In the end, you will spend the same amount or more but you will have put a ton of your time into it when you could of just bought a TT in the first place. This is all assuming you do the swap yourself, you wouldn't even want to know how much a shop would charge to do the swap.
For example, if you send your Z to Z1 in Georgia, they will do the swap for you for $9k (includes the front clip)
