MoogieBoogie wrote:Are aftermarket rotors/pads noticeably better than stock? I've always thought that stock Nissan parts were best, given that Nissan spent all the time on R&D.
The stock brake hardware is definitely not as good as it could be.
This is for a number of reasons, not the least of which being that it was all designed in 1988.
Furthermore, stock brake pads are designed to produce very little noise and dust, often at the expense of braking capacity. The brakes on the stock S13 are certainly adequate in all normal street-driving applications, they're not in any way dangerously inadequate, but upgrading rotors, pads, and lines will do a world of difference if you plan on pushing it a little. I also recommend Motul 7 brake fluid.
Getting Z32 brakes with huge aftermarket drilled/slotted rotors and carbon-metallic dust-tacular brake pads is obnoxious overkill for normal street driving. Also, upgrading only the front brakes with larger calipers and rotors will kill your stock brake balance, which IS near perfect, so you don't want to mess with that. Upgrade all four corners to Z32 or not at all.
