RMiller »
https://forums.nicoclub.com/rmiller-u12169.html
Fri Nov 26, 2004 8:39 am
Sure it can. You should be working instead of asking questions though. My second time swapping my CA it took about 2 hours to get the KA out and the CA mounted. Figure an hour for all the wiring, an hour for driving places and getting fluids you forgot, wire connectors, etc, 2 hours for stuff you would never think of, a half hour to bolt up the exhaust, an hour(at least) to bolt up the intercooler and trim the bumper, at least an hour to install the guages nice and pretty, half hour to swap the cluster ('90 tach doesn't work) or just the tach, another 3 hours for stuff like power steering, running your vacuum lines, using 50 zip ties, and stuff I can't remember.
Let's see, by my exact science your swap will take 12 hours. So in Oklahoma you started at like 9am, and you'll be done at 9pm. Seriously though, I could do it in a day and so could some other guys on here, but it probably takes others at least a few days to finish. It depends on who you've got working on it with you. I recommend air tools to speed things up...so satisfying.
