how fast do you guys go on 5th gear 3krpm?
dvd
I'm feeling a little paranoid but when i'm on the freeway and going on 5th gear around 3k rpm, i would be going 65-70mph depending on road condition(slight uphill or downhill).
I have a stock ca with ca transmission and a vlsd off a 96 180sx
Akihisa
Car: 300zx, Italjet Formula 50Lc, Italjet Dragster 180
According to my GPS mine goes 67 at 3150 rpm on the SAFCII.
mikesim
not relavent since i have the 4.36 FD; mines 80kph
dvd
Akihisa wrote:According to my GPS mine goes 67 at 3150 rpm on the SAFCII.
hrmm ok its not just me then.
OmarM
Car: 1989 Nissan 240sx HB
I have the 4.36final drive but then again I have 225/50/16 (f) and 245/50/16(r) and I do about 60mph at 3k in 5th, i know cause I have tested it with one of those police radars that are on the side of the street numerous times.
boost_boy
77mph @3k rpm in my sentra.
Dee
dvd
maybe cause i have 17in rims running 225 and 215. Oh well. Thanks for the responses, and damn you dee you dont have to rev high to drive at normal speeds.
Akihisa
My speed is with stock diff. and 255/40-17 tires.
kapower06
75MPH at 3k ....
for some reason it wont show the picture, just right click>view image
kapower06
And this is with a USDM speed sensor and stock tires/rear-end/ transmission, the speed-o is only off by about 3-4 mph tested with a cops radar gun. And the tach is correct from what i can tell, same speeds at same RPM the Ka used to be at with stock tach.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
what the crap. mine is only doing about 55 at 3k and im turning 4000 at 74mph.
- tim
c-rad
Car: 1991 Nissan 240SX w/CA18DET
I don't understand... the CA has the same gear ratios as the KA, so it should read the same (ie: ~70mph @ 3k). Only difference in S-chassis trannies is with the SR which has a slightly taller 5th.
EDIT: I'm wrong... its the CA that has the lower 5th gear...
*CA18DET(RWD)* *S13 SR20DET(RWD)* *KA24DE*1st 3.321 3.321 3.3212nd 1.902 1.902 1.9023rd 1.308 1.308 1.3084th 1.000 1.000 1.0005th 0.838 0.759 0.759R 3.382 3.382 3.382
Modified by c-rad at 10:05 PM 2/20/2006
DjLiquid
Car: 1988 Nissan Pulsar
Yeah, I don't like the idea of having my engine run at 4000k (or 110km/h) for 2 hours straight if I plan on going out to my cabin in the summer. Is there anything I should do besides getting a better cooling system?
MikeDombeck
Car: 1995 Nissan 240sx SE S15 SR20DET
c-rad wrote:I don't understand... the CA has the same gear ratios as the KA, so it should read the same (ie: ~70mph @ 3k). Only difference in S-chassis trannies is with the SR which has a slightly taller 5th.
my ka went to 30 in 1st, yet only 27 in my CA
dvd
just making sure, u guys using a ka speed sensor on the ca transmission right?
c-rad
http://www.nissansilvia.co.nz/...e.htm
Edited my post above... I was wrong. CA has a slightly lower 5th gear ratio .838 vs .759 in the KA/SR
c-rad
CA gearing....
KA gearing...
81na ZX
Car: 81 280ZX, 69 Lotus Europa
Hell, I went 75-80mph (3.90 w/ a stock 81 L28E) @ 3000rpms
Only 68mph calculated with a ca18det transmission
XTCshri2222
Car: 1978 Datsun 280z L28ET Powered
1991 S13 Ca18det coupe - sold
r34 gtr wrote:what the crap. mine is only doing about 55 at 3k and im turning 4000 at 74mph.
- tim
thats what mine dose
float_6969
LOL! I just plugged mine in there. CA 5th gear + 4.363 Diff @ 7K RPM = 136mphI'll be turning about 3600RPMS @ 70 mph. That's funny....
kapower06
There is absolutly no way that at 3000 rpm im only doing 62mph, im pasing everyone in sight and they do about 65-70, while my speed-o is reading 75. The only thing I can think of is my brand new auto-meter tach is off? I hope not. But it shows that correct idle rpm. And shows the same RPM as the stock ka tach showed for the same amount of speed. Is it possible that my transmission has a different gear set, The fluid was really clear and new, plus 1st goes about 38-40 then second to about 68-70. I can damn near get 105 outta third. 4th nails the speed limiter as soon as i get into 4th from the top of third.
r34 gtr
you have larger wheels on your car? ive got some 17s on mine and it causes the speedometer to be off by about 5mph.
i can get about 25 out of first, 45 out of 2nd if im lucky.... im turning 3600 at 65 on the interstate. why is my car geared like this? is it possible ive got some kind of crazy nissan motorsports gearset or ring gear? its just really odd.
- tim
Ca_Silvia
I got a digi dash in my silvia and i got 97km/h in 5 gear @ 3000rpm thats perfectly stock i might add, no new diffs or trannies.
Hope that helps
dvd
i have 17s on my car =] Maybe i should ask my brother to drive his stock car to drive next to me on the freeway.
mbmbmb23
CA 5th gear + 3.96 Diff @ 7K RPM = 161mph
Also.........heres a cool calculator site with some helpful calculations;http://www.rocky-road.com/calculator.html
-m
kapower06
stock wheels, stock sized tires, stock diff.(open), The transmission was very clean. the input shaft looked very clean, the half-a-quart of fluid that was left in it was nice and clear still. I dunno but the gearing seems longer then my ka's gearing. And the only possibility is that my tach is off, but if so its progressively off as the rpms increase. The idle rpm on the tach is correct. I dunno im stumped but Im going to put a video up on videos.streetfire.net of me going through 2nd,shifting around 7krpm, to third then letting off of third at about 7k rpm, I think I may be able to pull 110-115 out of third. I dunno but im not going to try either.
video>http://videos.streetfire.net/p...39A33
Modified by kapower06 at 1:06 AM 2/23/2006
dvd
Ok i checked using one of those police things on the streets. My speedometer reads 5mph faster than what it really is. I wonder is that linear though, like would it be 10 mph less as speeds go higher =\
boost_boy
kapower06 wrote:stock wheels, stock sized tires, stock diff.(open), The transmission was very clean. the input shaft looked very clean, the half-a-quart of fluid that was left in it was nice and clear still. I dunno but the gearing seems longer then my ka's gearing. And the only possibility is that my tach is off, but if so its progressively off as the rpms increase. The idle rpm on the tach is correct. I dunno im stumped but Im going to put a video up on videos.streetfire.net of me going through 2nd,shifting around 7krpm, to third then letting off of third at about 7k rpm, I think I may be able to pull 110-115 out of third. I dunno but im not going to try either.
I think it is very possible to pull such speeds out of 3rd gear. At 7550rpm, my car is at 115mph, so it isn't totally out of the question.
Dee
