Mettler wrote:That's some pretty hard maths to figure out, because having a gearbox bolted to the back of the motor biases a lot of the weight towards the rear of the assembly.
The weight either goes into the front crossmember through the engine mounts, or into the gearbox crossmember (and therefore roughly the center of the chassis) through the gearbox mount.
I must complain about your choice of words here, its sounds like you are trying to say that the position of the engine mounts or gearbox mounts has some bearing on the weight distribution of the engine/gearbox... that is not true, simple moments the engine and box will act the same regardless of the offset of engine or gearbox mounts. Further more i'ld like to say that the "SR20 handling" will never really be obtainable with a TT'ed Vh45DE and z32 box. your are simply adding too much mass in front of the vehicles COM (centre of mass).
However if you want to get a similar weight distribution it could be done with a recessed firewall. But why?, the "amount of SR20 handling" (<-- I use this as a very loose term) you will loose by only mounting the engine as far back and low, without cutting the firewall would be minimal. If you want a road car then rear mount the battery, use FRP gaurds and bonnet and use a light weight turbo manifold with bracing and make up a sheetmetal inlet manifold use the shortest thinest intercooling set up possible.
With +700hp why are you so worried about the handling? if its a race car and thats why the concern for the weight distribution, then cut the d@mn firewall easy!
Its not hard or complicated really, its just expensive to get someone else to do it thats all
(BTW i dont mean to rain on your parade)
