HOW FAR DOES AN AFTERMARKET COMBO STICK OUT FROM THE HUB??????
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
HERE'S A DIAGRAM OF MY SETUP, SO THAT I KNOW EXACTLY HOW FAR MY WHEEL TIRE COMBO STICKS OUT FROM THE HUB, COMPARED TO STOCK....
AS YOU CAN SEE, WITH MY SETUP, MY TIRE STICKS OUT 1" FURTHER COMPARED TO STOCK... IF NECESSARY, I CAN EXPLAIN THE FIGURE, BUT IF YOU STUDY IT LONG ENOUGH, YOU SHOULD SEE HOW I GOT THE NUMBERS, AND BE ABLE TO DO YOUR WHEEL/TIRE COMBO FOR YOURSELF
**NOTE**
1 inch = 2.54cm, and 1 cm = 0.3937008 inches....
so 245mm = 24.5cm = 9.65"... and so on and so forth
mcheddadi
Car: R8
thx for the great info! I'll save that image on comp.
Thx to you, I know that my tires won't rub. With my 19x8.5 +40 and 245/35-19 tires , I think I'll go get the springs
TheBourneAltimatum
Car: 2007 super black nissan altima 2.5s
TURN THE CAPS OFF LOLZ!!!!!! thanx for the info though
rjdmmfl1
TheBourneAltimatum wrote:TURN THE CAPS OFF LOLZ!!!!!!
yeah, i noticed it after I finished the first part, just too lazy to go back and fix it
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Great right up Doc! I'm sure this will help put a lot of other members here
