articzap »
https://forums.nicoclub.com/articzap-u92607.html
Thu Jun 26, 2008 6:10 pm
I used a KA clutch on my CA. I did as I read online and removed one dowl pin and drilled out some of the holes.
Now I'm starting to read that you should remove all of the dowl pins and drill all the holes.
So am I going to have to pull my transmission to redo the pressure plate or do you think it'll last a while.
