Movingviolation240 »
https://forums.nicoclub.com/movingviolation240-u104.html
Thu Oct 10, 2002 7:46 pm
it's not individual throttlebody's, there are 8 intake runners, and there is a plate that blocks 4 of them off at low RPM's. Then as you speed up they open. This is to keep the velocity up on the intake charge so you get better low end grunt.
If you want to test to see if it's them just find the vacume diaphram on the end of the intake manifold (it's hard to see cuz of the firewall but it's there) and pull the vacume line off it. Then drive it and see what the car dose.
Other problems could be the timing, TPS, or just your plugs getting dirty and the car surging. Also have you checked your cam timing lately?
I know I delt with that same problem like a year or two ago but I can't remember what exactly I did to fix it, sorry I can't help you anymore.
later,paul
