AJ-SPEC »
https://forums.nicoclub.com/aj-spec-u4904.html
Sun Apr 13, 2003 4:39 pm
what's up, you can mod an na 240 fairly easily. they use the same basic bolt ons as your average civic (intake, headers, exhaust, crank pulley) but they are a little faster. on this if you have an lsd, I've seen mid 14's. if you run a 50-75shot and can drive, mid 13's. suspension wise, since our 240 is the same basically as the silvia in Japan, there is an asston of mods, just depends on your budget and how you are going to use your car. as for the motor, there is a ****-ton of stuff for the sr20 also, as this is the standard motor in the silvia. other motors may require a bit of modification
