hungryjoseph »
https://forums.nicoclub.com/hungryjoseph-u50257.html
Sat Mar 14, 2009 7:45 pm
you can think of it as doing alot of simple things. thats what the swap basically is, a lot of simple things you need to do one after the other. i guess you can watch the dvd from drifting.com, which i've seen, and i think is quite useless. the best thing you can do is keep yourself organized, ziplock bags to keep your bolts and nuts in, with marker to write where they came from. being careful not to strip things. taking things step by step. using your common sense. keeping your tools organized. reading through the walkthroughs can help. they will give you an idea of what you need to do in what order.
