jontylerhttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113how easy is a brm 2.5" exhaust with resonator to put inSun Jan 21, 2007 4:17 am
Postby
adrianfromthecastle »
https://forums.nicoclub.com/adrianfromthecastle-u30128.htmlSun Jan 21, 2007 12:03 pm
if your stock exhaust has been untouched (i.e. not welded or anything), then its a basic plug n play once you get your hands on the underside of the car. its probably easier if you get your hands on a garage lift, but it can be done with jackstands. you should probably get a new cat while your at it, like a high flow cat or something like that.
Postby
Logan76 »
https://forums.nicoclub.com/logan76-u38992.htmlSun Jan 21, 2007 1:47 pm
The cat will hinder flow, get a test pipe or a high-flow cat, If your cars all stock right now make shure you have alot of PB blaster or WD-40, and maybe a small propane torch.
