how does this system look
Colton92
Car: 2008 Nissan Altima Coupe 2.5S - WinterFrost
Hey guys I am looking into getting subs in the near future and am looking at few things.I plan to buy a box like this most likely. http://cgi.ebay.com/METRA-S110...%3A50
This Sub Alpine Type R 4ohm 10" http://www.crutchfield.com/p_5...p=111
This Amp http://www.crutchfield.com/p_5...p=115
and the amp comes with a wiring kitits near the bottom. http://cgi.ebay.com/Rockford-F...%3A50
Will the box work cause it says it has a cutout diameter of 9 1/4 Inches, but the sub says it needs a cutout diameter of 9 1/8 inches.
How does this look? Any input on amp, subs, wiring kit quality would be greatly appreciated. Thanks for yalls help,
Modified by Colton92 at 4:20 PM 5/12/2009
Modified by Colton92 at 8:38 PM 5/12/2009
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
9 1/4 is bigger than 9 1/8 so it should fit in fine I believe.
The ebay links arent working for me, none of the links are working for me.
Curtieson
LongBeachCoupe wrote:The ebay links arent working for me, none of the links are working for me.
Dito, I think you posted them wrong.
Colton92
Fixed the links
Curtieson
LongBeachCoupe wrote:9 1/4 is bigger than 9 1/8 so it should fit in fine I believe.
That means it will fit in the hole, but will there be enough room to put in the screw holes? I would be slightly worried that the screw holes would be 9 5/8 inches apart which would 1/4 to put the screw on a 9 1/8 inch opening, but only give you 1/8 to screw into on a 9 1/4 opening.
I have never ever mounted a speaker before however, and maybe you use brackets to mount them...I don't know...but someone will correct me if I am wrong.
Colton92
thats what i was worried about
AppleBonker
The mounting holes are usually closer to the edge, so you should be ok.
I'm not sure about that power wiring kit. It probably has crappy quality power/ground wires. You may want to think about investing in a better kit. 4AWG should be fine. But since the power is such a pain to run, you wont want to redo it. It is always best to spend the money on good wiring so you don't have to tear the car apart again to replace. I use a lot of Street Wires (I'm pretty sure) in my car (can be had for relatively cheap on ebay). RF wiring kits are also pretty good.
As far as the amp goes, Doc might be able to help more. He knows his RF stuff.
I know a lot of people that have been happy with Alpine Type-Rs. They're good subs.
Crazyirish
Car: Nothing noteworthy at the moment...
Hit up Broadfield in the nico sponsor section. He's a cool guy and has good prices on JL and Alpine gear.
Colton92
AppleBonker wrote:The mounting holes are usually closer to the edge, so you should be ok.
Yeah thats what I was thinking about today regarding the wiring kit. Thanks for the help
Crazyirish wrote:Hit up Broadfield in the nico sponsor section. He's a cool guy and has good prices on JL and Alpine gear.
I will definately look into that thanks.
