C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed Jun 16, 2004 11:17 am
I ran 6.5 PSI on a FMU for a year with no detonation. I am running an E-Manage with 370's now and had to back off timing a bit, but that has to do with the fact that the ECU thinks less air is actually going into the motor then there actually is, so it adds more timing advance.
The stock timing curve is pretty conservative as it is. Considering it is written to run on 87 octane fuel. And at that the stock curve is such that at WOT, timing is advanced more similar to base timing(20 BTDC). Under cruising conditions is usually where timing tends to have the most advance as it sees less load and the advanced timing helps to save fuel.
