Last week I was driving around the block and all of a sudden i heard a loud a** pop and my car died. Pulled over then I tried to turn it back on and all it would do was crank. Pushed it home, sat for about a week til I could tear into it. Took off the top timing cover and found my timing belt half eaten. So i thought, hmmmm maybe timing belt jump or something. Then I thought it could be my CAS. Looked online for symptoms of a faulty CAS and sure enough I found a thread about a guy saying he had the same loud pop and it was his CAS. So today I was tearing into the Rb again to try to replace the timing belt cause it needs one regardless. I started spinning the crank manually and noticed the exhaust cam gear was slightly bent. I was like "wtf, maybe that's why my belt is chewed" Took off the valve cover to have a better look, spun the crank again and saw the gear spinning but the actual cam was not..... Then took off the the CAS bracket and the gear came with it..... The cam gear completly snapped off the cam.
So i now see why my car died. Cam no spin CAS, CAS no send signal to ecu, Car dies.
Now my question is how does that just break off? and could I have possilbly bent a valve or something?
