how does the KA react to nitrous?
midnightclubbaa
Car: Cars Clothes Music Girls
i'm looking to slap a nitrous system on the old KA for a little speed until i can afford a swap. could i do a 50-75 shot and still be able to drive my car everyday and not have problems.
NateDogg
If you do it right, no problems.
Don't forget to retard timing and use colder spark plugs.
TheOne
Car: 93 240sx FB
and have replacement spark plugs in case something happens.(after some shots, the spark plugs will probably get eaten by the nitrous and cause all sorts of stuff associated to that)
midnightclubbaa
so a 75 shot is safe for a daily beater
Big Manne
Car: cars, muzic, females
midnightclubbaa wrote:so a 75 shot is safe for a daily beater
it is on mine milton. though i think i killed my rings. by the way whats up manne
midnightclubbaa
nuttin much manne i thnkin about slappin nitrous on my ride
jksstar
Car: 99 Nissan Altima
if you don't use it every day, I have been running a 65 shot for about 2 months. Just start with a 55 shot and if the car is ok with it then move up to a 65 shot and so on. Aslo make sure you get a wet kit.
midnightclubbaa
why a wet kit?
Big Manne
midnightclubbaa wrote:why a wet kit?
i have alwasy been told that it is more safe. im using wet kit on mine
midnightclubbaa
anybody have any problems with nitrous and their KA
Dattebayo
Just so you are aware, your engine will wear out much quicker than before...
Although I am pretty sure that is common knowledge, you should always have the internals checked before upgrading to such a radical change in power. If anything is out of spec down low or worn from high mileage, you could set your self up for disaster.
You must also be aware that there are rules about when you can apply the gas and when you should never, ever use it.
