How does the HKS SSQV work
CCXLsx
I dont understand how the HKS Super Sequential Blow-Off Valve work, its a pull type bov, I dont understand how it works. could someone please explain it to me, and maybe how it compairs to standard push type bov
Silvia007
Car: 93 Nissan 240SX SE Fastback
the HKS SSQ BOV is designed to prevent leaks. My Type S leaks like a SOB but it's recirculated and it keeps my turbo spooling so I like it. The SSQ no matter how much boost you are using it won't leak a single bit of air mainly because the pressure also helps hold the valve closed.
CCXLsx
Does it install the same way as a push type? and I thought you could get a recirc. adapter for the HKS
fiznat
Car: Grown up :(
you can get a recirculation adapter for the SSQV, I have one:
how the thing works, however, I am not completely sure. You can google sequential valves someplace and figure it out... I thought it had something to do with working off of vaccum instead of + pressure... Could be wrong though-- hey it makes a cool sound!!
CCXLsx
Was it hard to install?
yelnatsch517
Car: '95 Nissan 240SX
I read somewhere the pressure keeps the valve closed until there is a vacuum which then opens it up. Or something along those lines. =)
Def
Car: Cars, Engineering Stuffs
http://www.hksusa.com/products/more.asp?id=792
As you can see, pressure keeps it closed. Also of note is that there are two sections. The adjustment screw changes how easy it is to push the small plunger back, which then releases the large plunger. So it's good to have it set about as loose as you can get it.
